It is currently Thu Aug 21, 2025 9:44 pm
PostPosted: Sat Aug 31, 2013 3:21 pm
First name: Larry
Last Name: Hawes
I am shaping and thicknessing a new neck/peghead and don't have the Grover Sta-Tites I'll be using on hand. See below.
http://www.stewmac.com/shop/Tuners/Guit ... ?tab=Specs
Searched all over and found nothing definitive. Anyone else use these? What thickness should I shoot for with the Peg head?
Thank You and Best To All
PostPosted: Sat Aug 31, 2013 3:23 pm
I did 16mm on my last one (with Sta-Tite tuners) and there is *juuust* enough room to not cause any problems.
Edited to fix incorrect measurement.
PostPosted: Sat Aug 31, 2013 4:13 pm
Last Name: Sonksen
City: PORTLAND
State: Oregon
Zip/Postal Code: 97216-2013
I managed to get mine onto a 16mm peg head, or just under 5/8". I think anywhere between 1/2" and 5/8" and you're good
PostPosted: Sat Aug 31, 2013 4:31 pm
You could measure the distance from the centre of the string hole to the peghead face on a guitar you like (and that has enough space for the appropriate number of winds on the E string) and then subtract that from the string post height of the Sta-Tite... Got to take the bushing into account too, of course.
Just a newbie trying to contribute, please correct me when I'm wrong.
PostPosted: Sat Aug 31, 2013 4:42 pm
First name: Larry
Last Name: Hawes
Nick Royle wrote:
About 12mm?
I did 14mm on my last one (with Sta-Tite tuners) and there is *juuust* enough room to not cause any problems.
Thanks for the reply. (I don't have a set on hand nor do I have a guitar with them to measure hence my question.)
PostPosted: Sat Aug 31, 2013 4:44 pm
First name: Larry
Last Name: Hawes
Thanks John. This is actually my first solid peghead as I've been building slot heads where thickness is not as important.
PostPosted: Sat Aug 31, 2013 5:10 pm
My apologies, I just measured it and mine is 16mm too, not 14mm. I wouldn't go any thicker.
The bushing is about 2mm, the string post to string height is 21.21mm, so a 16mm peghead gives you 3mm for string winds and a 15mm gives you 4mm, etc.
PostPosted: Sat Aug 31, 2013 5:42 pm
First name: Larry
Last Name: Hawes
Todd Stock wrote:
.75" - .80" for slot head and .600"-.625" for paddleheads.
Thanks Todd
PostPosted: Sat Aug 31, 2013 6:35 pm
Last Name: Sonksen
City: PORTLAND
State: Oregon
Yeah I like this for the size, it doesn't show a lot of exposed threads on the tuner posts
